Technical Wipers control not working
Codebreaker
Hi guys!
I'm in need of some assistance. My wipers don't work, but let me explain.
They stopped working gradually. Sometimes they would work and sometimes they would. When they finally died the only way I could turn the wipers on was to set it on a desired speed and then squirt some water and then they start going in the desired speed.
I took out the control unit and disassemble it and it seems to be fine form electrical point of view. I measured the resistance coming out the 3 pin connector and it changes resistance on pins 1 and 2 depending on the selected speed (third one is for the button on the handle).
It goes like this:
  • Full speed - 0 ohm
  • Normal speed - 93 ohms
  • Intermittently - 316 ohms
  • Off - 1160 ohms
Are these the correct values for the speed selector on the control handle?
Assuming they are I tried to find the relay box to check there but the cables go behind the steering wheel and I could not reach there.
Where is it located? My conclusion is that the motors are working fine since the wipers work then squirting washer fluid. The switch works because there are different values when rotating the switch and I could turn them on by engaging the wiper fluid squirt. The only thing that remains is the relay box that I cant find. Any help?
Car is Fiat Grande Punot 1.3 Diesel 55kW 2008.
Thank you!
The "relay box" You're talking about is actually the Body Control Module (aka BCM) and is located under the dashboard behind/under the fuse board...
Crawl under you wheel, warp/wry yourself and you'll eventually get at it after loosing a couple of finger on sharpies steel parts, be careful! Disconnect the plugs and inspect for corrosion/moisture/pulled pin etc.
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
Thank you for the information!
I went down under and I'm sad to say I didn't find anything. Behind the fuses is empty space (IMG1). When I engage the washer fluid squirt I can hear the relay in the fuse box (IMG2). Since that the only thing there am I to assume that this is the BCM? Googling the serial number does say that this is a "Comfort Control Module"
Am I on the right tack to diagnose the issue? Could it actually be the problem with the BCM? Because my car mechanic claims that the problem is the control handle that and wants almost 250 euros to fix it (which is almost 10% of what I paid for the whole car, seems a bit much) but my testing shows that the wiper speed control switch does indeed "switch". Could I be mistaken with testing?
I checked continuity and resistance measurements on the 3-pin connector coming out of the handle on the control unit as well as on the output pins on the control unit. Checked the continuity on the PCB traces.
I just got home so I'm going to disassemble and take out the control unit and check the voltage on those pins and see if I can possibly trigger the wipers manually.
Very good idea, mimic the stalk with a set of resistor/switches and see how the bcm respond ...
BRs, Bernie
Fixed!
The problem was... disconnected header pin on the PCB in the control unit. The solder on the pin was pressed against the cooper and since it was a tight fit, connecting and disconnecting the connector didn't move it (I'm sure it did when connecting but then returned when disconnecting) and it's the reason I didn't see it being soldered properly. Had to clean it and resolder the pin to the PCB.
What still baffles me is why I got 1160 ohms on the output of the handle connector pins and when I soldered the header pin to the PCB it was 2k ohms. It wasn't connected to anything, open circuit. I'm sure it was my mistake, but how...
In hindsight, an easy fix.
Thank you for all the help!
Thanks for the update and congrats for your pugnacity !!
BRs, Bernie
Fixed!
Hello, I seem to have more or less the same problem with you. My wipers sometimes work and other times they won't stop working unless I squirt some water. I'm having a hard time understanding which control unit you are referring to. Is it the fuse box or what? And what header pin? I kinda confused, any help would be greatly appreciated!
My wipers work on highest speed only, so I'm assuming problem is in resistor. But my question is where can I find the resistor?
Hi have you find the problem?
Hi, have you find the problem?
