Technical  Window rocking.
M1kbee
Warrington
My front passenger window tilts forward when it is buzzed down. This means when it is wound back up someone has to hold it back against the frame so it feeds in properly.
Anyone have any ideas on this one? I have had the door card off and the connection to the regulator seems solid.
Right. I've had the panels off and found a little white clip that goes inside the rubber seal has broken. Got a new one from fiat and broke it trying to fit it.
Does anyone know how to fit them properly?
I have the same issue with the breaking of the white clip that goes into the hole in the window glass. The motor seemed ok but I've bought a whole new mechanism. Can the white plastic bit be replaced on its own then?
Thanks for your reply,
I've bought the entire regulator including the white bit,from eBay, and I was looking for the rail fixing points but now wondering if it's only the plastic white bit needs replacing !
