Technical Wierd wiper issue
derbyshire gp
Derbyshire
My wipers have gone a bit crazy
passenger arm is working fine as it should,drivers side goes straight off the screen and gets stuck in gutter channel or stops halfway on screen and then gets caught on passenger side arm ?
Seems really loose no resistence on arm compared to passenger side?
easy fix or is it a new wiper motor?
Re: Wierd wiper issue SOLVED
Now solved:D
After checking eper and haynes manual for the setup of the wiper system i set to work
The nut holding the arm in place was very loose so upon tightening back up sorted :slayer:
The kind of fix you need:) free easy and sorted by yourself .
Now solved:D
the nut that holds the wiper arm to the serrated output shaft..??
you wonder if somebody had attempted to remove the arm.. as usually they are VERY snug on the tapered mount..
Hi
charlie I Recently had springs done so wipers and scuttle panel would have been off so guess mechanic or his trainee didn't seat it correctly or tighten up enough.
