Yes, but, although I've never seen anything else in a Punto I'm couldn't swear that there are other options on the late models? - Being as how I only work on older ones.All FIRE engines are port- indirect injection type.
Punto NEVER got a FIREFLY motor until its end of production. Panda, Tipo and 500 did...Yes, but, although I've never seen anything else in a Punto I'm couldn't swear that there are other options on the late models? - Being as how I only work on older ones.
Multipoint is not Direct Injection. Look at the first pic you've posted. Nearest to the camera, bottom left, is a grubby white stopper in the end of the fuel rail (which puzzles me as it's usually a black cap like on mine?) anyway your injectors are underneath this. If you look at the second picture I think you can see two of the wiring connectors going down between the inlet runners? That's a port injection engine.I took a look at the manual and it says it has electronic multipoint injection system for the models 1.2 to 1.4.. im not familiar with this multi point injection system![]()
So your saying that multipoint injection is the same as multiport injection and in essence it's sprays gasoline on the valves and not past the valves like a direct engine does? If this is treu what you stating then an oil catch tank is not necessary for this engine? I googled around a bit today and couldn't find a real clear answer.Multipoint is not Direct Injection. Look at the first pic you've posted. Nearest to the camera, bottom left, is a grubby white stopper in the end of the fuel rail (which puzzles me as it's usually a black cap like on mine?) anyway your injectors are underneath this. If you look at the second picture I think you can see two of the wiring connectors going down between the inlet runners? That's a port injection engine.
When fuel injection first appeared on "everyday" cars it was often done with a single point injection system. This was basically like a carburettor body but instead of all the carb insides - float chamber, jets, etc - it contained a metering body which injected the fuel into the airstream. This allowed for much more controlled fuel delivery and thus improved fuel consumption and better control of emissions. However it was quickly realized that the long interior surfaces of the manifolds etc allowed fuel to condense out into a liquid on the surfaces and also that the cylinders nearest to the metering body (typically numbers 2 and 3) would receive a slightly different mixture compared to the outer cylinders (1 and 4). injecting the fuel directly into the port for each cylinder sorted out a lot of that problem and also allowed "clever" things to be done with the injection intervals to further enhance economy and emission control. So was born "Multipoint injection" (some call it multiport).So your saying that multipoint injection is the same as multiport injection and in essence it's sprays gasoline on the valves and not past the valves like a direct engine does? If this is treu what you stating then an oil catch tank is not necessary for this engine? I googled around a bit today and couldn't find a real clear answer.
Wish I did, Ha Ha!But that said, I think I know now almost everything about injection systems
It's just means there 4 injectorsI took a look at the manual and it says it has electronic multipoint injection system for the models 1.2 to 1.4.. im not familiar with this multi point injection system![]()
