T
Tom
looking at the fix, i will prob try this.
need to buy soem antifreeze also from halffrauds.
but will this work
Cooling System Bleeding the Cooling System on a 1.6
2 bleed screws, 1 on the rad (top drivers side I think) and 1 on the heater
hose down behind the engine. The hose has a kink in it and the screw is in
that.
Turn heater on first! You can't bleed it with the heater off.
open rad bleed screw, fill rad with water until water comes out of screw.
Replace screw.
Open heater hose bleed screw, fill rad until water comes out there too.
Replace screw.
Start engine, wait 2 mins.
open heater bleed screw, rev engine. Water should pour out, if not rev
engine a bit more until water does gush out. replace screw quickly
If you just get air or steam then return to the first step.
leave running for a bit longer, confirm heater is hot.
If you get lots of bubbles and smoke then the head gasket has had it.
If the heater is cold then start again from the beginning.
but will this work
that.
Replace screw.
Replace screw.
