Technical  Wheel nut tourque
Alex 13
Hi have a panda 1.1 active 2005 with stock steel wheels and plastic wheel trims and well some **** at the tyre fitters put the trims on wrong (miss aligned with the notch for the air valve nipples) and due to fiat's design the wheel nuts hold the wheel trims on so I need to know the correct tourque for the wheel nuts (yes I have a tourque wrench)
Hi.. top cars :)
As it would appear youve not been too familiar with the job itself
You dont need to jack up the car ;)
The wheel bolt adjacent where the valve cutaway of the trim currently is..
CAN STAY IN PLACE
Undo the other 3 bolts..
The trim will then wriggle off ( it has a slotted hole.. so can be 'hung'on 1 bolt)
Once the trim is removed:
Reinstall the bolt nearest the airvalve on rim.. hand tighten.. to moderate torque
Hang the trim on this bolt..whilst slotting the air valve through the trim ;)
Then install the other 3 bolts again.. moderate torque
Once youve got all your trims seated correctly
Roll car forward @6 feet-2 metres
Then fully torque all bolts
SEARCH on here is great :
https://www.fiatforum.com/500/337447-500-wheel-bolts-torque-values.html?337447=#post3356919
The tyre place really ought to be doing this for you.. :eek:
Their paperwork should advise retorqueing at 100 miles anyway..
Charlie
Thanks but rather not have to fork out more money for what is really (as they would put it) a cosmic issue and since I have the tools I thought I should give it a shot as I've all ready spent far more than I can afford getting this car up, running and on the road so can't afford more atm
No problem..
I meant they should be correcting it for nothing.. ;)
But if you are happy to swap them yourself.. thats fine :)
Charlie
Alloy wheels are 72lb/ft (92N/m) and steels wheels less. I think 60. The hand book does tell you. Had the front strut off my 169 today so looked this up for the alloy wheels in the workshop Manuel.
Which workshop manual as I was got a Hayes manual and can't find any mention of it maybe I'm missing it
No problem..
Charlie
Well we all know how places love add on charges, well I just ran through a tourque check on all my wheel nuts atm to 60 Newton meters and delighted I had as one of the nuts was loose (given I have not loosened any yet) now tight to 60 all rest at least 60 phew dam garage from now on I will always double check there handy work
Its Haynes. Its at the start of chapter 10. Its also show on an electronic one I have on cd.
Found it thanks very much it wasn't where I expected it to be in the book so for anyone needing these here they are 85 nm for steel wheels 98 nm for aluminium wheels or in lbf ft its 63 lbf ft for steel wheels and 72 lbf ft for aluminium wheels
