- Joined
- Aug 2, 2021
- Messages
- 240
- Points
- 129
SEARCH on here
In Advanced.. you can find what you need pretty well![]()
but for my own car I would probably just use a couple of extra self tapers
Self tappers are OK but winter salt will kill them in one season. Rivnuts are far better just smear the hole and the RivNut with copper grease before fitting and use the same on the screw. Don't use a stainless screw into plated steel as the plating evaporates quickly followed by the steel going very rusty very quickly.
I concur.not sure I understand this inner wheel lining are held on with self tappers on virtual every car I work on
including
Fiat
Vauxhall
Mercedes
Honda
Peugeot
most are over 10 years old.
If your car has that amount of rust on the wheels and wheel arches, I'd be concerned for the condition of:
Has it lived its life in an aggressive/coastal environment?
- rear axle spring pans
- coolant return pipe across front of engine
- engine sump pan
- shock absorbers & springs
- mud trap behind front springs
- brakes (build-up of rust on sliding surfaces of front calipers & inside of rear drums)
- exhaust bracket below cat
- rear sills (access to treat rust via rubber bung in rear wheel arch and base of b-pillar)
however there is a mud trap in that corner.
I did notice the mud and snow marking on the tyre and the outer edge looks to be feathering
including
Fiat
Vauxhall
Mercedes
Honda
Peugeot
Self tappers direct into the wheel arch metal (to replace a broken stud as discussed above) are a very bad idea. .
They are self tappers into plastic blocks. Great until someone butchers a screw head or strips out the plastic. OEM plastic blocks and screws are great, but they usually get replaced with B&Q self tapping screws with predictable results.
Self tappers direct into the wheel arch metal (to replace a broken stud as discussed above) are a very bad idea. They always rust and the panel ends up damaged.
It only takes one to really ruin your day and I've had a few.
both the wings and bumper on the panda are into metal spring clips. Which normally slide and scratch the paint off anyhow.
I have to confess I have done just that. Only two, one in each footwell but I might remove them and spray the resulting hole with Bilt Hamber Dynax if I think the liner is secure enough without them.
in a body shop they tend to spray any cut edges with zinc primer as soon as they are cut.
There's no need to over complicate things. As long as water or air can't reach the bare metal it can't corrode
