Yesterday I had the 'opportunity' to experience an MG ZS for the afternoon. (The SUV, like a Nissan Qashqai) Not impressed.
After over 120 years of car manufacturing, it should not be possible to make a bad car, but Tesla tried very hard to do so, with build quality that 1970s British Leyland would scorn. But the MG is rather more subtle.
Inside, it looks good, and the seats are comfortable, but the trouble starts when you try to adjust them. They were electric, with the standard controls on the seat side, but there was a delay. Pushing the control back, nothing happened. First reaction was to let go, and recheck which one we were supposd to push. Push and hold, and after a momentary pause, the seat moved.
Seat adjusted, time to start the engine. (At least a proper engine, not electric) Clutch down, felt strangely vague. Engine started, select 1st gear, oh! The gearshift is odd. Lots of travel, in all directions, with hardly any feel of what it might be doing. But despite the long travel, it felt like it hadn't quite gone far enough to engage the gear properly. The remaining five felt similar. Reverse was more difficult, with strangely little movement of the lever, giving the feeling it was nowhere near engaging, which one out of every two attempts, it wasn't. Clutch pedal feel was also a bit vague, leading to less than smooth moving away, until more used to it, but always hard work.
Steering, no feel, but the car did seem to go where pointed, although neither of us were trying hard, so the vehicle dynamics were not tested. The wheel moved, the car changed direction, without feeling any real connection between the two. There did seem to be a physical steering column, so presumably connected to the rack.
Once moving, it did accelerate adequately to make progress, and stay with traffic. It did need lots of gas pedal movement to achieve though.
Now we need to stop. Oh dear. Push the brake pedal, gently, nothing. Push a little more, definitely moving the pedal, still no braking effort. Add a little more, ah! feel something, a little more resistance, the brake pads have at last started to squeeze the discs, but retardation is still a wish rather than reality. Add more pressure, and suddenly, it bites. Incredibly difficult to achieve a smooth slowing down. This will encourage drivers to arrive too fast at everything, then brake late, as the opnly way to master the car. This increases the risk of the one behind hitting you.
Overall, very hard work to drive. This car is a great incentive to reduce one's carbon emissions, by just not going anywhere.
Then we needed to adjust the ventilation system. A strange mix of a few buttons and a touchscreen. Not very intuitive, and just not quite like any other car. Instead of simple logic, it needed careful thought, not good when moving. What looked like the touchscreen controls for an auto climate system, was just a manual system, so all settings needed to be adjusted by the driver, or passenger. Selections change from white to green. White is not selected, green is selected. Although the white is brighter, and more prominent.
Radio comes on every time the car is started. This gets irritating. There does not appear to be an 'off' option. Pressing mute, only available on the steering wheel, every time gets tedious, so we just reduced the volume to zero. The button for this seems to need to be pressed repeatedly, rather than just hold.
There's a reversing camera, but it gets dirty within a few hundred yards, so is of little use. Taking it out of reverse, the screen changes to the front view. There's a camera in the front grille. Why? We have a glass windscreen. I suppose it should stop you hitting a small child, or other object below the bonnet line, but the screen is very distracting, and in a car park, with spaces ahead and behind, a little confusing.
After just 3 hours, very glad to give it back. hopefully won't get another any time soon.
