I'm not a big fan of 6 speed gear boxes, you seem to spend most of your time stirring cogs.
The 5 speed you spend a lot less time changing gears.
That said a car like a TA has a narrow power band so benefits from having an extra gear.
You'd probably find on the TA. 6 speed would be much more manageable
it isn't. I have the 5 speed dualogic and the turning circle is the same.I didn't think the turning circle was just a sign of the 6 speed gear box
The 6th gear of the TA105 isn't an overdrive though. The TA105 needs in 6th gear more rpm to drive a certain speed than a TA85 in 5th gear!I quite like the 6-speed box in my 1.4 Sport. In 6th it's like an overdrive and makes for a pretty quiet and relaxing cruise on motorways.
As far as I know the 500X has the ZF 9HP gearbox, which isn't a CVT.9 speed autos are a bit of a joke basically they are a cvt box that can be programmed to have as many gears as you want, they don't have 9 physical different gears.
Maybe for the DL, but assuming its a similar setup to the Panda then the 6-speed manual will have a much wider turning circle normally.
@yostumpy: Why this hypothetical question? You can't get a TA105 with a 5-speed gearbox, at least not in a 500.
I'm pretty sure Audi were the only European manufacturer to persist with cvt but they've given up and now only use twin clutch or 8/9 speed torque converter auto boxes.As far as I know the 500X has the ZF 9HP gearbox, which isn't a CVT.
http://www.goauto.com.au/mellor/mellor.nsf/story2/9CA5C8A1DDA9440FCA257E040023160E
https://en.wikipedia.org/wiki/ZF_9HP_transmission
Without seeing the power/torque curves I'm not sure but that's my perception.so does that mean the 105 is less 'flexible or driveable.'' but more punchy.
