Nought to do with power, all to do with chassis flexure & hard suspension would put more stress on the chassis that way. The centos are effectively braced at the front and rear of the car but not the middle, where the driver is. This leads to flexing around the driver. You can put a full cage in or you could brace the roof and door sills which would also help reduce chassis flexure.
allanhelen; if you actually look at it that area should be one of the first to go as it'd a junction point for the, relatively, flexible middle section & the stiffer rear section. Just after the B pillar there's a Z shape then straight into the rear arches. Also the shape makes it a prime place for stress as it's in the seat of 2 L shapes quite low down on the body, below the B pillar that adds the rood torsion to any stress that area of the panel is under
