Technical what oil for jtd?
southend on sea, essex
what oil do you use? i currently using millers 10w 40 semi synthetic for turbo diesel's, its time for another oil change, well not quite, iv only done 4k but i need to do a flush, iv got to buy it from ebay cos i have the money in paypal you see ;) and i cant get it out.
iv been reading that 0w40/5w40 is better for cold start ups? maybe this is why mine sounds so clattery/tappy when its cold with the 10w40 :confused: i dont really understand oil :p only want to spend about £25.
http://cgi.ebay.co.uk/SHELL-HELIX-D...oryZ9895QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
and does anyone know if engine oil has a use by date? as id imagine the ebay oil is old stock at cheap price.
oh i need a new sump nut too, anyone know what size it is? does it need to be from fiat? or can i just fit any old bolt in there? lol
have you got the forte engine flush yet? get that first
dont you read :rolleyes:
iv bought the stuff yes.
on shop4parts, they have a sump plug and it says for 99-03 mk2 punto, all engines.
are all the plugs the same? :confused:
if so i need a favour off someone who uses shop4parts and has paypal ;)
it should be ok as they're sealed containers, you need more than 4L though.
what sump plug have you got as most fiats are tapered fit whereas mine isn't and has a washer which you replace when changing oil
you sure? my last oil change i used a 5L oil bottle, and its got about half a litre left in it, and iv been doing top ups every few weeks, if its over 4L it must be like 4.2L? or something.
i dont know but i know its badly rounded off and im sure it was a torx bit, not allen key.
mines an 8mm allen key, the one on shop4parts is tapered fit 12mm allen key
one has a slight taper the other has a flange which tightens against the washer and sump
the tapered one normally sticks out a little and you can see the thread
