They look right, thanks!
No problem mate,, any other problems just ask i will try and helpThey look right, thanks!
Would speaker wire be okay to use as electrical wire to extend the wire on my led's up to to the interior light? Its 2core wire just like the stuff I need and it's the same gauge if not thicker so would this be okay to use?
I soldered mine upto the terminals of the light positive to negative so if you have done that it should work when you power off the bulb but not sure and the fuse is in the glove compartment behint a metal shield thing i think its held on by a 10mm bolt not sure about ur car and the fuse was the top right and i think its a small 10 amp thats what i have used cuz of the led'sI took out the interior light today and I have a different set up. It looks like this:
http://stuff.jamesweb.net/images/PuntoLight3.jpg
https://www.fiatforum.com/gallery/data/600/IMG00106-20100501-1535.jpg
But I read through on the guide and the second picture is how someone else who had the same light done it. But I don't really understand what he's done. Know how I can do it? Thanks
No probe mate! did it work now??Thank you mate! Instead I've now wrapped the end of the wires around the points where the bulbs pushes in, no soldering required and it looks tidier and is a very strong hold, and easy to remove again thanks
Looking gd small simple mods to start off with is the best. Then work up to bigger mods. Such as lowering etc. Like the vinyl wrap could mabe wrap your pillers in cloth or do what ive done and wrap them with black leather and install some after market speakers?
Or mabe change yout LEDS in your dash to blue?
How much and where did you source the leather? Is it faux?
