I'm thinking about regassing my aircon but all i'm seeing on Amazon are "R1234YF compatible" kits, like the one below. What exactly are these? Whats going on?
I'm saying just go with what the car itself / manufacturer says and take no chances basicallyYou both seem to be saying different things. Andy saying its R1234yf with some helpful extra oils. SB1500 that compatible might not be R1234yf, but another gas.
I had a look under the bonnet and there were no stickers/info of relevance, however on the silvery metal pipe there is what i believe to be the Aircon "Low" valve. There was no sign of how much gas to put in there, but i'll have another look.
I had a routine nurse check up recently and it was so nice to be in an air conditioned room - i thought i must get my car(s) done! Even if summer is over half way.
I will be doing this job myself, i don't see the need to use a garage, it looks fairly straighforward...![]()
I am of this mindset too.I'm saying just go with what the car itself / manufacturer says and take no chances basically
What car is this ?
Regardless you need a set weight of refrigerant and a set amount of lube oil for a proper job .......
"Extra oils" sounds like bull to me, you need a set amount in your vehicle
Look your car up in: https://www.mahle-aftermarket.com/media/homepage/facelift/media-center/klima/thermokampagne/2021/2-2-handbuch-fuellmengen-pkw-&-nkw-210112-en-screen.pdf
Fiat's are on page 45 , 3rd column is refrigerant type, 4th is how much, 5th/6th is lube type, 7th is how much lube.
Does the aircon work currently, even if it is weak are you getting cooler air out the vents ?
Mmmm. Thoughts?
Just had my recent purchase Hyundai i10 done by my garage, as ac wasn't really 'cold' just a slightly colder than the non ac.Just pay a specialist aircon to evacuate , vacuum test and refill with the correct qty of ingredients..
It doesn't cost a fortune and will ensure the charge will stay in the system (and not leak out)
DIY is just a waste of time and money, you need to know the system is capable of holding the new charge, and also the correct amount of lube will ensure the various seals and other elements of the system are in tip top condition.
It's just not a DIY job imho ., pay a little bit more to be done by a professional and have it done right....
The availability of DIY kits doesn't mean it's a good idea, they just want to sell the(ir) product at the end of the day.
It's akin to the availability of aerosal spray paint....
Yours does sound an expert job, but for me it'd be more likely that the garage stuffed it up, overcharged me or put a crowbar onto something.Just had my recent purchase Hyundai i10 done by my garage, as ac wasn't really 'cold' just a slightly colder than the non ac.
Garage did the whole lot there and then and allowed me to watch. First, evacuated the whole system. Then, pressure tested with a dye penetrant to see if there were any leaks, and to see if system held pressure. Purple dye was put in, and syatem pressurised and put up to pressure, (no refrigerant used at this stage) once required pressure was reached, system was allowed to sit, and pressure was monitored for leaks, and all joints watched for the purple dye which would show where they were. Small signs of dye at a couple of joints, and, pressure dropped slowly as the dye was pushed out of the joints.
Appears that 'o' rings had perished slightly, so were replaced, and retested. Once pressure was stable and no dye emerged from the joints, system was regassed with refirigerant and oil up to pressure. Then was tested for 20-30 minutes to see how it stood up. Now have a fully cold a/c with no leaks. Total cost, £75 all in, including testing, dye and refrigerant and oils and labour. For what it's worth, my i10 uses r123-A gas, not r-1234yl
For what it cost, peace of mind, and well worth the money. Certainly woudn't have been able to do the same job as well with a 'home kit' that's for sure.
2 weeks later, still ice cold (and with this weather, that's a BONUS!)![]()
I could take any of my 3 cars to the scrap yard tomorrow and not care in the slightest, so if my DIY goes wrong, it doesn't matter. There are a lot of cheap Fiats out there![]()
If you re-read the first sentence of my last reply all will become clearI'm not being funny - and you can obviously do whatever you want , but I really don't understand the reasoning , as has been said a professional specialist can do a complete test and fit for £75 (not untypical pricing) , but you want to try this DIY kit for £69 which doesn't do even half the job, it won't test that you've got a gas-tight system and the oil content isn't specified at all ?!
If you re-read the first sentence of my last reply all will become cler![]()
No need to worry about it.I'm sorry it doesn'tthe price difference between your original ama... link and HighJarsse's example pricing from a professional for a complete job is just £6
I'll leave my thoughts and contribution on the idea there
As regulars on Dragon's den often say.....
Building an understanding with a garage helps, it allows you to trust them, and makes the interaction go well. I used to do this, and baring the odd blip things were good. But since covid it seems almost impossible to find a good garage, not just a good garage, but a dentist or vet, probably other professions too. Oh well, I digress.The garage I use is a small independant family owned garage. Dan, Josh, and Dean are 'proper' mechanics, and, because I'm an engineer, (and a nosy old fart as well!!) and have a fair idea of what needs to be done, and the guy's know this. Dan believes in doing the job once, properly, and is willing to take any info onboard. He did let me see the process, as he thought it would show the complexity of the job. He also said that if done wrong, can result in the compressor packing up if incorrectly filled or tested, and that if there is a leak , and the refrigerant leaks out without you knowing, and you still run the ac, then this will do damage that can result in a complete new wvaporater and compressor. Having seen the complete system from start to finish, the £75 was certainly worth it, as, even as an engineer, with 50+ years of experience, the kit he used and the need for the highest understanding of the way it works, was an eye opener. No way could you replicate that with a home kit, for sure. Just getting the mix of oil/refrigerant etc, and the correct operating pressure for the cars system? No way!!
But, each to his own.
aircon likely needs a regas but if there is no cold air at all it need hooking up to a proper aircon recharge machine to do a full vacuum and leak test then put in the correct amount of gas oil and dye which you cannot do without the machine.The aircon is electronically sound, it blows but no cold air comes out of it. It whistles much like i've read that an aircon that needs regassing should.
