R richardc316 New member Joined Feb 20, 2011 Messages 22 Points 7 Dec 19, 2011 #1 1.2 elx mk 2 2000. Its the passanger side, side light. Is there a part number? Thanks Richard
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Dec 19, 2011 #2 Rear Passenger Side Light Or a Front Passenger Side Light As for the Bulbs - there standard sizes, Pop the bulb out - go down to halfords, get a monkey to find the correct bulb for you If its a Rear Side Light - its a 12v 10W if he gives you a 12v 5w, slap him around the face with a cod if you put a 5w in a 10w spot it'll work fine BUT will throw up the bulb error/malfunction error everytime you put the side lights on I think the fronts a 12v 10w as well actually Ziggy
OP OP R richardc316 New member Joined Feb 20, 2011 Messages 22 Points 7 Dec 19, 2011 #3 Ziggy122 said: Rear Passenger Side Light Or a Front Passenger Side Light As for the Bulbs - there standard sizes, Pop the bulb out - go down to halfords, get a monkey to find the correct bulb for you If its a Rear Side Light - its a 12v 10W if he gives you a 12v 5w, slap him around the face with a cod if you put a 5w in a 10w spot it'll work fine BUT will throw up the bulb error/malfunction error everytime you put the side lights on I think the fronts a 12v 10w as well actually Ziggy Click to expand... Sorry, i knew i'd forget to put something! It's the front.
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Dec 19, 2011 #4 Its dead easy to pop the side lights out nip down to halfords or even a local parts shop- they'll have them in To remove - squeeze its holder and pull out, then simply pull the bulb outs its holder Ziggy
S s and b Distinguished member Written 5 guides Joined Mar 13, 2011 Messages 7,620 Points 1,453 Dec 19, 2011 #5 if its capless its a 501 5 watt
