What are the symptoms of...
G
Greg
a clutch slave cylinder going....
and the thrust bearing....
Just have an issue with the clutch where it feels like the pedal is catching on the way down and on the way back up but I also get moments where the clutch feels heavy or takes a bit to get it to disengage - like a pop then it realises and goes down ok.
I got a question, the bite point of my clutch is way to high, why is this?
@ Greg...you still at RAF Waddington??
If you are I can pop up and have a look for you, my release bearing went on my old one, so know exactly what it feels like.
@ Griffy... its because it's wearing out!!
As a clutch gets older the bite point moves further away from the floor.
A mate of mine bought an escort for £50 with a knackered clutch and the bite point is so high you can change gear so quickly because you only have to put the clutch down about an inch or so!!
SEX...I'm just two women short of a Threesome
@ Lee
not down at Waddo at moment but will be back down soon - probs weekend near end of the month if thats ok!
Its just strange as like tonight its worked fine all night! hhmm
Yeah no worries,
Gimme a text/ring on 07736 830931 when you are back here and ill arrange to come and take a look for ya!
Might just be one of those FIAT things!!
my slave cylinder packed up , the hand break light came on every so often , got it fixed and didnt do it any more, this happend twice as they fited a dodgey slave cylinder. you lose break fluid when its f*kd so check this also.
Loss of brake fluid, spongey pedal, bitting point isnt in the same place, oil under the batt tray
Members Site - - - - - - - My Site
Well its doing none of them symptoms so I guess its not a leaky slave cylinder
thrust bearing...?
Release bearing maybe, I had this happen on my old one, the pedal gets about half way down and then it clicks and drops to the floor.
1
7K
Dark Lurker
K
2
1K
Dark Lurker
2
730
Sabre 23
S
T
1
297
M
