Technical wet driveshafts -- anyone know?
Liverpool
The Xmas Cinq has a completely knackered outer driveshaft boot -- split all the way round -- so I doubt if there's been any grease in there for a long time: I recon the joint is probably a goner. But I do have a low mileage wet 1108 driveshaft.
It'd be quicker (I think) and easier to do a swap rather than faff about with the boot.
Anyone know if it'll fit?
The cinq 899 C501 gearbox looks to me to be identical to th Seic C526 one so I'd say it should fit.
Why not take the good CV off the 1108 shaft and put it on the 899 shaft.
Its an easier job anyway, as if you use the 1108 shaft, the spiders are the same, so should go in, your going to have to take the spider off to get the bearing for the inner boot onto the 1108 shaft.
I think the lengths might be different, which is the big question that I cannot answer, sorry.
SPD
