So...
As you may expect I have stumbled across some rust. Some of it I can repair with tin and soldering (not sure how to call it in English), but the other has eaten away some non structural panels.
Yes, I know that one should cut the beast out, make/get replacement metal part and spot-weld it back in place. At least what a conventional wisdom tells us.
But, as we are in 2026 i.e. XXI century why not to use modern technology or better say chemistry?!
I am speaking about 3m structural adhesive bonding line.
As far as I know the main 3 products in the field of weld free panel attachment are:
The 08115 is the strongest but it will partially pull itself from the panel in case of stress.
The 08116 is the one which will brake internally leaving a coat on bonded panels
And the 07333 is a mystery for me.
I know from a fact that nowadays Fiat recommends 08116 as it leaves that protective layer of adhesive in case of an accident not letting the metal to be exposed and rust to occur.
I am calling for our forum knowledge here: what should I use for repairs? Mainly I will do a small panel behind rear wheel arch (one facing the bumper) with intention to rivit it for additional strength (mot that I think it needs it but anyhow).
Thanks gor your opinions!
- 3M 08115
- 3M 08116
- 3M 07333
- Model
- Barchetta
- Year
- 1999
- Mileage
- 293000
