Technical Water in passenger footwell
skjsolutions
Hi we keep getting water in the passenger footwell and it’s coming from a metal unit behind a pull out panel on the centre console. The unit gets hot and water leaks from round a rubber bung that doesn’t fit very well. It seems to leak whether the ac is on or off.
Not sure if this part of the ac?
Ok the scuttle drains are clear so it’s not that. I have attached pics of where the water is coming from
Have you checked my post with the same issue? I resolved it.
Ok thanks, can you tell me where the drain is and I will take a look - Steven
In the middle just above front section of the exhaust.
Turn A/C on first and if you sit it dripping from above the exhaust then it won't be that. If it is dripping from the left hand side near the sill anf front wing then the pipe will be blocked.
I pulled the heat shield away as it was squashing the drain pipe and lots of water came out. Hopefully that has solved it. Thanks for all your help.
It certainly worked for me and I am 99% sure it will for you too. Happy days.
