Hi all rear washer jet working fine but no front working when u pull washer stalk back you cant even here pump working checked fuse(f20) do you gain access to pump through removing front wheel then remove arch liner ??
When I removed steering wheel it couldn't be fitted any other way but one. It had a indent in the back of it to stop it being able to twist.Sounds like a failed stalk unit. I'd try being a bit 'firmer' with it and see if that works. Might be worth stripping down the switch unit before ordering a replacement as it might just need a clean up.
You will need to remove the steering wheel and airbag, and when you remove the steering wheel make sure you line up the steering so the wheels are straight and then secured the clock spring in the central location before stripping the switches down
Oh yeh lol. Ignore me.That not the reason why, steering needs to be central so you can secure the clock spring in the central location
hi again just to update went out and tryd stalk with a bit more pressure and it works ok but not with normal pressure
I'd say that is common problem on Bravo.
