Technical  warning triangle
jonezy8873
hi, i have a yellow warning triangle with ! in middle. no other info on dash. had around 4 months, now before i take it to fiat to get it checked out i just wanted to ask you guys.
its a duelogic 1.4 sport,
it comes on with one turn of key BUT if i press break and start it stays on but if i rev it to about 2500 brev or just a quick burst while from ignition off to engin start it doesn't come on.
so to recap
if i start as normal or just turn key one turn the light comes on (not all the time which is confusing).
if from off and it neutral foot on break turn key engin start if i rev it aswell NO LIGHT ??????????
please help me guys im skint and hoping for a miricle.
bit more info, when light is on it will stay on all the jurney.
i have looked at all external lights and all working as should.
thanks.
Could depend on type of lights if they have a different current rating the yellow triangle light show due to a less current drainage this is how they detect of the lights are blown as on my car I have led side lights and the triangle is constantly on due to this,, sometimes goes off but it could be that hope it helps :)
thanks for the reply
they look standard i think? it was from a garage had 1 owner it was a 50 year old man.
Yehh probs will be standard have a look at the connection between the front lights under the bonnet and see if anything is loose :) is a round connector check clips are locked,,
No worries pal,, if no luck and when u take it to the garage see what they say and look around before you go with them as they charge a fortune ?
GENERIC FAILURE
INDICATION
(amber)
The warning light turns on in the following
circumstances.
Engine oil pressure
sensor failure
The warning light comes on when the engine
oil pressure sensor is faulty. Contact
Fiat Dealership as soon as possible.
External lights failure
See what described for warning light 6.
Inertial fuel cut-off switch
intervened
The warning light comes on when the inertial
fuel cut-off switch is triggered.
The display will show the dedicated message.
Rain sensor failure
The warning light on the dial turns on
when the rain sensor is faulty. Contact Fiat
Dealership.
Parking sensor failure
(where provided)
See what described for warning light t.
Tyre pressure monitoring system
failure (where provided)
The warning light turns on when a failure
is detected in the T.P.M.S. system (where
provided).
Contact Fiat Dealership as soon as possible.
Should one or more wheels without sensor
be fitted, the instrument panel warning
light will come on and stay on until
restoring initial conditions.
Diesel particulate filter clogged
(Multijet versions)
The warning light turns on when the diesel
particulate filter is clogged and the driving
conditions do not enable to activate automatically
the reclaiming procedure.
To enable the cleaning procedure, keep
the car running until the warning light
turns off.
Hi , I'd get it checked out on a diagnostic machine to check for errors . My mate had the same sort of problem and just ended up replacing the oil pressure switch ;)
thanks guys for the reply's its funny how if i rev it then it does not come on though so i cant see it being a bulb.
i think i will get it checked out
Get a diagnostic reader on it buddy.
Mine is always on because my hill holder is not available.
Got a service last Jan and they cleared it. No problemo. Bit of a headache and worry though.
Massive list of codes online when you get it read as well to point to what it will be.
Prepare for a whole history/host of electrical problems :(
yeah think i will,
funny people kept telling me that fiat have electrical problems all the time but still such a beautifull car.
Ok so just had a bit of a fiddle pushed all connectors and in fuseboxed and tryed turning keyvover 20 times and not once did it come on. Shown the mrs she jumps in turns key and yes u guessed it warning triangle.
Starting to wish i bought the golf now to be honest.
well after another fiddle it has gone off?????
turned on off a dozen times but no triangle.
what the hell is going on?
What?!
Let's zoom out a bit here pal, you have a warning triangle on your dash, and your car runs perfectly ok.
Yet you wish you bought another car? LOL. Honestly, go and buy a Golf, but if a warning light comes on that then you can wave goodbye to your bank balance for a few months. :)
To put things in to perspective, I get this all the time, normally about my rear numberplate light, I check, it works, ignore. Problem solved eh?
edit: LOL between this and the other thread about hating the GP because the radio fades out when changing stations, I am actually lolling my face off.
What?!
you dont know what other problems it had do you?
no?
so wind your neck in pal!
thanks.
Enlighten me.
new window switch (still not working)
new drop links
radio stoped
power steering stoped
engine mounts needed sorting (i dont know what it was im no mecght the golf hanic)
most in warrenty but some other stuff too like stinks of petrol when stopped (breather pipe)
juddering when pulling off
clonking noise when pulling off
duelogic gears sometimes says gear unavailable
my friend bought the golf only problem he had was the key was a bit worn.
now do you see?
