Technical wanting to put the mk1 Abarth 1.4 in my punto
Jaybe
Cambridgeshire
well i hope to have a better response to my questions than my last try. anyway i am intending to put a mk1 500 abarth engine and box in my punto . it comes complete with ECU so now the questions as electrics is not my best. i am more mechanical fabricating anyway will the ecu be just a plug n play or will i need to change the pins around in plug?? also i saw a video on you tube that the guy was on about the fuse box . i am googling as much info on wiring as i can find . i know its going to be a headache for me but i am hoping you might know and be prepared to share with me .
It won't.
It won't be enough.
The cars are more like computers nowadays. There are several modules that communicate with each other.
FYI, that's how a 2011/12 Ducato BCM (body module) looks like:
The cab's fuses and relays are on top of it:
On the 2nd and 3rd photos the PCB is in the same position. The middle port on the bottom is the OBD2 port.
So, if you don't now a lot about it (and I assume you don't), just don't even try.
It won't.
It won't be enough.
View attachment 473953 View attachment 473954
Well I like a challenge. So what do I need to do to get to communicate with Brain. Is it the communication with the car it's self. I thought using the donor engine and it's ECU from that engine would work but the car electricals would need setting up. Computers weren't around when I left college you had to be an auto electrician to repair car electrics. And I was a car mechanic as it was called then so we didn't touch much electrics and when I worked for vag group we just plugged it in to our diagnostic machine and it would check everything. I don't know whom to ask if I can't find the information on here.
There is no single brain. There are six - nine of them. You need them to speak the same language.
The problem is the engine brain speaks 500ish, the other ones speak puntish...
I don't say it's not impossible, but I'm afraid it would be much, much more than a challenge for you.
There are Punto Abarths on the market - why not look for one of them? or as a neglected car to take care of, or as a donor?
I don't say it's not impossible, but I'm afraid it would be much, much more than a challange for you.
so its sensors that tell the ecu that all is correct in pick up that mine wont communicate with it being an punto ?? so i cant buy a brain for a 1360 punto abarth ? i call it a brain . so its not as easy as using wiring diagrams and using my multi meter to check signals or check sensors even splicing it . i am taking in what i learn as you can never know enough about things so thank you for explaining
The reason you haven't got many answers is your question has been asked many times before but different models/different engines.
The answer is always the same you are never going to do it , the electronic systems are too complicated .
The people asking the question never accept the answer ....thread goes on and on and on.
No one has ever come back with they did it successfully with an explanation of who they did it.
@the green vanper
Gave you the best advice in post 4
Ok understand. I will have to either change car or see what I can get from the 1.2 vvc I have in it . I ve done the usuals complete exhaust system de cat/ throttle pedal program / a piggy back afr adjustable program/K&N element/ cam would be next on the list. It is gutless still . Have to do a comp test . Well thank you and I didn't know it was a regular question on here. Plus since I adjusted the piggyback afr. engine management lights come on better on fuel so need to check plug colour then the comp and if need be have the head off . I must check a few things. 🤯🤬😡
I suppose I can't even put a 1.4 8v in my 2014 Punto Evo ?? Because of the same thing not communicating with each other.
It's more likely that such swap will work, assuming it will be the same generation of the car.
Find someone who tried it, he should confirm if it's doable and what kind of problems he's encountered during the swap.
I don't know the regulations in the UK, will it ever be street legal? I assume a car needs to have a road homologation, both of the donors had. What about the resulting car?
well that sounds a bit more promising than trying to fit the twin cam Abarth engine .my homework now begins trying to find a thread on changing the 8 v 1.2 to a 1.4 8v . how far back i wonder and what forum its on. if its been done and written about it . wish me luck "the green vapour" and i hope you can help me out further if i need further technically .
There is very little power difference between the 1.2 8v and 1.4 8v . It will not be worth the effort /pain/ cost let alone increased cost of insurance especially with all the other alterations you have made to your car.
You mentioned mil is on , you need a code reader to find out why it's on . You say you have taken catalyst out and fitted something to alter the afr, both of those things could turn on the mil.
If you want a larger more powerful engine the best advice you could receive is buy a standard car with better performance.
You mentioned mil is on , you need a code reader to find out why it's on . You say you have taken catalyst out and fitted something to alter the are, both of those things could turn on the mil.
thank for your input . i am not being funny but my 1275 mini cooper was quicker top speed and a damn faster acceleration but that was a few years ago and i was working in the trade. well now i love the shape of my punto apart from the blind spots
, its my new toy/mini . i cant help myself in trying to soup up my cars like i do my motorcycles i am a speed freaking petrol head . goes back to my youth when i helped out a drag car team.
Hi.
If you have any issues with insurance at all for this type of conversion then please feel free to drop me a line.
Regards,
Dan.
