Bonefish Blues
Established member
- Joined
- Nov 14, 2013
- Messages
- 454
- Points
- 206
Morning all, everything's going really well with the 4x4 - an interim oil change with Fuchs oil from Opie has quietened start-up nicely, and I have finally found the right length bolts to be able to fit the 5mm spacers to stop rub on full lock (I fitted 185x65s - as on the Cross, but haven't quite got away with it on 4x4 offset wheels, unlike some others!)
I'm also waiting for the car upholsterer to come back to me on the vinyl to fix the RH bolster - but I think we'll end up with a leather coloured to match, which is no problem (and more durable) if the case.
Just one minor niggle I'm hoping others can help me track down. It's a very slight vibration on gear change, sounds almost like an exhaust rattle. I know it's not a dual-mass flywheel because it hasn't got one, but could it be another clutch symptom - no issue with clutch bite point btw. Possibly engine mounts?
Any thoughts - it's not very noticeable, and I can eliminate it by consciously slowing changes, but I'm the sort who is annoyed by little annoyances, iyswim!
