i take it that this astra is the post 2000 model?
according to honest john, these are the problems with the astra saloon (same as the coupe, but slightly more boring)
What's Bad
Nondescript , 'hamster'-like road-hugging styling. Ride quality may be too firm for some. Is regarded as 'also ran' to Golf Mk IV and Ford Focus and does not hold its value as well. (This is something for the second-hand buyer to take advantage of.) Water leaks (see below). ECUs of 1998 to 2000 1.6 16vs can suffer from corrosion of resistors. ECUs are being replaced FOC on cars up to 4 years old. Springs fail in rear brake compensators and are not available as a separate part. A new compensator is £150 fitted. Timing belt and tensioner changes re-scheduled from 80,000 miles to 40,000 miles on engines which have them. Timing belts on 4 cylinder 16v engines also drive the water pump which can shed its impeller blades and seize, throwing off the belt, so best to change water pump too. Tensioner bolt which passes through oil pump also prone to fracture, leving belt untensioned and apt to fly off. Reports of gearchange problems with 2.2 petrol. 2.2 16v petrol engine has been known to snap its timing chain due to the lubrication jet becoming blocked, possibly as a result of running on dirty oil due to extented oil change intervals. Ignition control unit of 2.2 petrol engine is prone to burning out. Hesitencey of 1.8s between 1,500 and 2,000rpm now cured by a software download to the ECU. Rear springs can break due to damage by road humps. Overactive alarm fault quite common. Needs new ECU.
What to Watch Out For
Nearly-new examples likely to be ex-rental, so look for signs of careless driving such as kerbing. Check front tyres for uneven tread signifying suspension misalignment. A batch of faulty sealant left some mid-1999 Astras prone to condensation inside the headlights and foglights. If it has aircon make sure aircon blows cold. Lift front carpets and check for water underneath. The cure is either re-sealing the front bulkhead or re-sealing the pollen filter carrier. Blower fans fail. May also mist up because vent flap mechanism has broken. May also mist up because water drips down wiper shaft and soaks pollen filter. See recalls about noisy power steering pumps. The old Vauxhall Cavalier & Vectra steering column failure seems to have re-emerged with the G Type Astra, though Vauxhall will usually pay the replacement costs. One report of premature cat failure at 3 years and 35,000 miles. In this case, Vauxhall paid 50%. Drain plug threads strip on aluminium sumps of 1.8s. Exhaust manifold of 1.8s prone to cracking and Vauxhall quote £700 because it contains the car converter.
Recalls
Depending on source of supply, some models developed noisy power steering pumps. Free-of-charge replacement programme spring 1999. 14/7/2000: 3,008 3-door models built between January 1998 and October 1998 recalled for replacement of front seat adjuster spring which can lose its tension. (Press release received 15/7/2000.) 2001: TSB about voltage spikes from the alternator damaging the camshaft sensor. This is prevented by unpicking the wiring loom and re-routing the cam and crankshaft sensor cables together around the front of the airbox, keeping them away from the alternator. 22-08-2002: 2,436 Astras VIN range WOLOTGF3522184592 to WOLTGF672BO14989 recalled because batch of brake calliper pistons may release hydrogen gas into brake fluid. Where found to be from faulty batch are to be replaced.
