C curly43 Member Joined Jul 14, 2010 Messages 69 Points 69 Sep 2, 2025 #1 Hi all anyone know the valve clearances on a 1.2 8v 2002 punto
G George1982 Member Joined Sep 1, 2022 Messages 38 Points 62 Location Corinth Sep 2, 2025 #2 curly43 said: Hi all anyone know the valve clearances on a 1.2 8v 2002 punto Click to expand... In cold engine,the inlet 0.3 mm and the exhaust 0.4 mm What kind of symptoms do you see?
OP OP C curly43 Member Joined Jul 14, 2010 Messages 69 Points 69 Sep 2, 2025 #3 George1982 said: In cold engine,the inlet 0.3 mm and the exhaust 0.4 mm What kind of symptoms do you see? Click to expand... Trying to sort out a misfire , building up another cylinder head to try.
GrandePunto PL Established member Written 10+ guides Joined Apr 22, 2018 Messages 1,232 Points 422 Sep 2, 2025 #4 https://aftersales.fiat.com/elearns...§ionName=Dati Tecnici&validityName=1.2 8v
OP OP C curly43 Member Joined Jul 14, 2010 Messages 69 Points 69 Sep 3, 2025 #5 Thank you all much appreciated
chevychase Member Written a guide Joined May 17, 2016 Messages 92 Points 102 Location Swindon Nov 6, 2025 #6 Did you get a new head built up? Have you sorted the multi misfire? I have been following since the start of the year and wonder if you have an update?
OP OP C curly43 Member Joined Jul 14, 2010 Messages 69 Points 69 Nov 10, 2025 #7 Have head all built up but not had time to fit yet still driving it , hopefully if we get some good weather I’ll get on and fit it cheers chevychase
