Technical user manual
clifford59
hi all, i need a manual for a 1996 x230 ducato 1.9td. please can anyone help.
hi FreeSpirit, had a look on e-bay but i dont think i fancy spending £33.75 for something that tells me what all the switches and dials do. i think i,ll need something more technical that will allow me to work on the van myself. shame they dont make a haynes manual for ducatos. thanks a lot for your suggestion. i.ll keep looking.
Hi clifford59
Sorry i thought you were looking for the owners manual as you did not say it was the Workshop manual you were looking for.
If it is the workshop manual you are after then all I can say is good luck as there has been no 230 model DTE or eLearn CD as yet found "loose" on the net & they were available on CD from the Fiat Technical website but the eLearn has been replaced with the KeyLearn on USB stick the 230 model CD is no longer listed as are any of the CD versions.
The only manuals I have found & have downloaded on the 230 models are in languages other than english - in PDF form scanned from a hard copy.
Cheers
hi FreeSpirit, thanks for the advice. ever the optimist, i'll keep looking. failing that, make it up as i go along.
93 the only thing that existed either in book form or in the form of a notepad, so it was not at all as I worked in the Peugeot and data were needed to J5 or C25, you wilekim optimist if you think that you find a book service, and but
http://allegro.pl/fiat-ducato-peugeot-boxer-citroen-jumper-82-2002-i3626230833.html
unfortunately only in Polish, Ducato 82 to 00, but what is the translator or Poles in England
rate of about 6.9
Richly illustrated guide dedicated to professional service and repair of vehicles FIAT Ducato , Peugeot Boxer and Citroën Jumper, produced since 1994 , and Fiat Ducato , Peugeot J5 and Citroën C25 , produced from 1982 to 1993 , equipped with gasoline engines XM7T a 1.8 dm3 ( 169B ), 2.0 dm3 XN1T type ( 170B ) , XN1TA ( 170C ) and XU10J2U ( RFW ) and diesel 1.9 dm3 undercharged a XUD9A ( D9B ) 230A2.000 , 230A3.000 , XUD9AU ( D9B ) , 230A . 000 and 149B1.000 , 2.5 dm3 type CRD93L/U25/661 , 8144.67 and DJ5 ( T9A ) and the turbo type 230A3.000 1.9 dm3 , XUD9UFT ( D8C ) and 230A4.000 and 2.5 dm3 type CRD93LS/U25/673 and 8140.27 , with mechanical gearboxes . Given such service plan , detailed description of maintenance and repair , can be taken in-house by the user and wiring diagrams .
FIAT DUCATO
PEUGEOTJ5
Citroën C25
Models 1982 - 1994
gasoline engines
1.8 dm3 of 51 kW (69 hp)
2.0 dm3 of 55 kW ( 75 hp)
2.0 dm3 of 58 kW (79 hp)
2.0 dm3 of 62 kW (84 hp)
diesel engines
1.9 dm3 of 51 kW (70 hp)
1.9 dm3 of 60 kW (82 hp) turbocharged
2.5 dm3 53-55 kW ( 72-75 hp)
2.5 dm3 of 68 kW (92 hp) turbocharged
2.5 dm3 of 70 kW ( 95 hp) turbocharged
FIAT DUCATO
PEUGEOT BOXER
CITROËN JUMPER
Models 1994 - 2002
gasoline engines
2.0 dm3 of 80 kW ( 109 hp)
diesel engines
1.9 dm3 of 50 kW ( 68 hp)
1.9 dm3 of 59 kW (80 hp) turbocharged
1.9 dm3 of 66 kW (90 hp) turbocharged
1.9 dm3 of 68 kW (92 hp) turbocharged
2.5 dm3 of 62 kW (85 hp)
2.5 dm3 of 63 kW (86 hp)
2.5 dm3 of 76 kW (104 hp) turbocharged
2.5 dm3 of 79 kW (108 hp) turbocharged
2.5 dm3 of 81 kW (110 hp) turbocharged
2.5 dm3 of 85 kW (115 hp) turbocharged
2.8 dm3 of 64 kW (87 hp)
2.8 dm3 of 90 kW (122 hp) turbocharged
2.8 dm3 of 94 kW (128 hp) turbocharged
Hello, I am new to this forum and also looking for a Workshop Manual for our 230 1,9TD from 1996.
In the meantime has anybody found a scanned or digital version from a Workshop Manual or a book in English?
I hope someone can help.
Thanks in advance!
We bought on Ebay the Pocket Mechanics . Citroen, Fiat Ducato, Talbot Express Manual. The pictures are a little bit small and not brilliant, but it helps
Then last week saw on Ebay a CD Disk which we bought and that is much better at least you can Zoom in on the pictures..
Bugger it says I cannot post a LINK ? ????
Have a look on ebay for Pocket Mechanic manual
NO LINKS TO BE POSTED ???
If not search TALBOT EXPRESS COMPANION SERVICE REPAIR RESTORING GUIDES MANUAL TUTORIALS ,,, Its all the same engine.
