Technical usb to radio
triballofts
hi is there an easy way to fit a usb to my standard car stereo so i can play music through usb flash drives
The only solution along these lines in the Panda I believe is to fit an aftermarket stereo or look on eBay for one of those Auxiliary In kits, but check your standard radio supports it.
There are tutorials in the Guides section if the Aux-In idea interests you.
One of these things may help:
Amazon.co.uk: car m transmitter
I use one in mine ...
thx, :)
hope that's what the OP is after..,
no use to me,as my poverty spec panda ( 57 plate) has no ciggy socket, :bang:
hence the realisation that a USB socket on an aftermarket radio would save LOTS of grief., ;)
Charlie
There's a guide on how to install a power socket on here. Check to see if you have the wiring already in place. If it is, you're more than half way there.
