URGENT help please!!!
  • Thread starter Rob
  • Start date
  • Replies 16
  • Views 298
R
Rob
Can't get into car this morning - am assuming it's just the battery in the key fob.
Nearest car place to get a replacement is a few miles away so dont really want to have to walk it.
If I open door with the key in the lock I know the alarm will go off - but will that stop once I turn the engine on or keep wailing away until I can get a new battery??
Anyone prepared to po out on to their drive & try for me??
Cheers,
Rob
manual
You can manually de-activate the alarm inside the car.
as you sit in the drivers seat, where your right knee is, there is a panel that has 2 plastic screws holding it in (need a flat implement to unsrew these, screw driver springs to mind) then in there you have some fuses but also a sliver keylock (may have a plastic rubber cover over it) you should have what can only be descibed as a "safety deposit key" when you bought the car, this key goes in that keylock, turn it 90 degrees of which way i can't remember but it will only turn one way and this turns the alarm off.
if you don't have this key your kinda screwed.
If so, give the key fob a good few hours to rest and then try unlocking again, electrons natually gather at the poles of a battery, even a very discharged one, thats why if you try to start a car with a flat battery that once it has died you can still keep repeating turning over the motor as long as you let the battery rest a few seconds.
putting key in
putting in the key in the ignition won't stop the alarm, if it hasn't come on when you open the door then turning the key in the ignition sets it off!
Re: putting key in
So let me get this straight. Fiats security system comprises a red key, a code card, an alarm key, and a blue key?
What a stupid bloody idea, i dont even think the dealers know how the stupid thing works. They blatently did it like that so when you lose one of the bits they can charge you $$$ for a new one!
my 2p
Jonathan
Re: putting key in
Damn! Im pretty sure i aint got one of these alarm reset keys :(
Better run upstairs and take a look.
Re: putting key in
ok, just checked the manual and it says "the key switch is not applicable to the U.K market"
pheeewwww! :)
P.S the key card isnt applicable either, somthing to do with u.k insurance companies
Re:URGENT help please!!
The keys for the car
Red key =1
blue keys =2
Alarm keys=2 see photo
This type of key will tune off the alarm
Via the fuse box to the right of the steering wheel
Trev
RED BRAVO HGT 147 1998
Re: Re:URGENT help please!!
I dont have these alarm keys, and the book says I shouldnt have them.
So, does anybody else?
i have them, aswell as a blue tag whith loads of numbers on it, that has somthing to do with the alarm.
Lee
Re:Re: Re:URGENT help please!!
But I have not got the code card
that's Fiat only
Trev
RED HGT 147
Re: Re:Re: Re:URGENT help please!!
Manual says both card and keys are fiat only thats why im confused that you both have keys!
Lee
The code you got is it for the ign keys chip to program the key in to the ecu
Trev
It could well be cant remember for sure, just gotr told not to lose it, also have a card for the immobiliser.
Lee
Re:Re: Re:Re: Re:URGENT help please!!
Just when I had to get a new key (under warranty)
I needed the codes on the paper tags
Trev
re
I'd guess ur new keys will have new tags>
my brava had two little alarm keys liek that!
i'm sure i still have them somewhere and coudl send one to someone if they needed it?
althoguh they are ary similiar to old keyboard lovk keys on pc's?
when you take the cover where the fuses are off do you have a litte round plastic cap? if yo do pull that off and you will see where you put the key in?
my car had it? so i dont know what ur manual is on about that it doesnt apply to uk market?
Re: re
One thing I have just noticed is that I do have a BRAVA manual and not a BRAVO, always wondered why there is never a mention of the HGT engine.
The plot thickens...
p.s i will gladly take one of them keys off you alan, but how universal are they (think about it, if they were all the same than I could spend all weekend breaking into bravos/bravas) but then this is fiat were talking about. If you find them i'll throw a small fee at you for it and the p&p.
A
5
787
M
G
670
garaint
G
B
2
669
Tommy K
T
