busta rhyme
Will the Uno Turbo engine fit in a Panda 4x4? That would be awesome to have a fourwheel drive Panda with turbocharge.. Are the enginemounts in the same places etc?
Point taken.No one thought a 2.0 16v would go in to the front of a Seicento, until it happened.
As you say a larger engine seems unessesary with the excellent engine range these days. The donor ECUs won't just integrate with the 100HP network. Best plan is to keep enough sensors in place to satisfy Panda electrics and lay the engine (and required body computer) from the donor on top. Until it gets very easy to interact and reprogram or control the closed FIAT CAN system, this will always be the case. I don't think that will ever happen in reality.A 1.4 turbo would be better though, it'd be lighter for a start so it wouldn't end up nose heavy. If you went down that route and you fitted the correct ECU for that engine and hooked up the canbus twisted pair would it play nice with the rest of the car's systems, so the trip computer etc would work?
Also Fiatseicento2002 any particular reason for a 500 engine, instead of a GP or Bravo tjet unit? I thought they'd all be the same, unless it was Essesse spec in which case a bigger turbo I think?
