Hi.
So I've had a long and annoying fight with my Fiat Punto 75 SX -97.
The last problem started out when I had the timing belt changed. I had an auto-mechanic that I know do the work and he was 100% certain that it was done correctly and he had no problems driving it back home to us. But the very next day my gf was driving the car to work and she noticed that it felt slow. When driving home from work it was running on three cylinders.
After a week or two of trying to figure out what was wrong I decided to have a workshop look at it. The immediatly said that the timing belt was positioned one cog wrong, so I told them to fix it.
After it was fixed it still ran on three cylinders...
Three weeks later, still no problems found, I had had it with them so I towed my car home. When I tried to fire it up I noticed that the battery was decharged. After recharging the battery with a battery-charger I fired up the engine and it ran on all four cylinders, weird.
BUT! now it had an uneven idle and it blurrs at first when I try to throttle and then revs up. Idle is moving around from 800-1100rpm and when I throttle from idle it goes down to 600rpm before increasing.
So I did a compression test (11bar, 11bar, 10.5bar, 10.5bar), had the sparkplugs changed, and tested the ignition system with a thingy I bought that has i light that flashes when you get a spark. This shows that all the cylinders have an equal spark.
I tried to measure the Ω on the ignition coils to see if they are ok without great success, I managed to measure the primary coil but I couldn't figure out how to measure the secondary coil. The primary was fine though.
I've changed the cable that goes from the ignition coil to the sparkplug (don't know the correct english term for theese being swedish).
One more interesting thing is that I have no warning lights on the dashboard come on when the engine is running. Not even when it was running on three cylinders.
My best guess at the moment is that one of the injectors fail to spray fine enough fuel mist so the drops in one cylinder doesn't get completly burned. But since there is a warning light for this on the dashboard that doesn't get turned on, I'm just not sure enough...
An injector costs the equivalent to £300 in Sweden, and thats to much for a guess.
So fellow fiat owners... Any ideas?
