Hi all,
we have a 2021 mild hybrid with 7" touchscreen. Wife said the display would flicker and then go dark but everything (touchsceen, audio , car play etc seem to be working ok.
It looks like theres something working on the backlight as the display changes to dark grey (is the backlight working but no signal to it ?)
Can bus seems to be working ok as the speedo display is mirroring the uconnect and all controls working.
I've stripped it down to check for damaged /loose ribbon cables etc but nothing obvious. (and phew everything else still works or i'd have been in big trouble with the mrs)
When powered up, the unit gets warm and I noticed the 12V fan isn't running with no voltage to it.
I saw a temperature sensor mentioned somewhere ? has anyone an idea where this is (the uconnect may be thinking its overheating?)
So I'm unsure whether its the backlight faulty or the signal to the display ? I can put a scope onto the display signals but not sure which cable is which .
So i could swap out the display only (expensive) or the whole unit (extremely expensive ) - but might just be a faulty ntc or poor connections.
Any ideas much appreciated (promise to share any brownies points if I can fix it).
TIA
TIA
- Model
- 500 mild hybrid
- Year
- 2021
- Mileage
- 36000
