Uconnect firmware 13.00.80.01
Uconnect Uconnect 5" firmware update: 13.00.80.01
No permission to download
Hello everyone on the forum.
I'm sorry but I do not know English well and I'm using a google translator.
I have a question about updating the Uconnect 5 'model 330 radio to the 500L Fiat.
Is it possible to change the default language that will be installed during the update, and what changes in the installation files do it require?
Thank you for your answer and Regards
So if i swap in a replacement it should just work, no need to set it up on the car with diagnostic software?
If you replace the unit with an aftermarket radio, as I did, you do not need to change the setup with diagnostic software. If you replace it with an used UConnect, I don't know, but there have been postings here from someone who did just that.
Brandy
Brandy
Thanks LordMetro. Sorry i had meant to reply to you before now. Yip, seems like a replacement head unit is needed then :( .
Ez2517, yes i was meaning swap like for like with a used one. Sorry i must have missed the other posts where others have done it. I'm sure i've read elsewhere that a code needs to be put in if it's come from another car hence my question. Thanks for your reply. (y)
Hello,
I'm new here. I bought a Fiat 500L 0.9 Twinair 2014 but had a gps problem.
The gps don't work. When I press the "nav" buttom the system stay loading and don't do anything.
I cannot acess the gps information like maps, system information, anything :confused:
I tryed to upload a foto but dont have permission to do it.
Any idea how to solve it?
Hello,
I don't own a Fiat Ducato but a Peugeot Boxer instead that I bought in 2016.
It has a uconnect 5 inch unit (it should be in a very old version, probably 2014).
Do you think I can install any firmware with CO (Continental) or are they Fiat exclusive?
If so, can I directly install the last version or do I have to update first with some older updates?
Thank you.
I have replaced my VP2 250 fiat DAB / NAV is it possible to chanage the Boot logo from Peugeot to Fiat. If possible how is this Done thanks
Hello,
First of all, TomTom have a warning that:
Important: If you have a Mito or 500L, 500L Trekking, 500L Living, please make sure that you have the correct software version that allows you to update your map (version 11.815.xxxxx or higher). To check the version on your device go to the Navigation Main Menu → Settings → Me and My Navigation → About My Navigation.
So this needs to be at-least version 11.815.xxxxx or higher! They mention that the dealership could solve this under warranty, maybe one of our later firmware's (CO version) may be able to help you out?
Maybe the usb drive with the tomtom home software is corrupted?
Follow these steps from TomTom:
To prepare a USB device, do the following:
Make sure that the map you want to update is the currently selected and active map in your navigation system.
If your navigation system has more than one map and you want to update a map that is not currently active, first make the other map active. To do this, go to the Settings menu and select Switch Map.
Go to the Settings menu and select Navigation Updates.
You are asked if you want to prepare a USB device in order to download updates.
Select Yes.
Insert your USB device.
Note: If the system continues to prompt you to insert your USB device, make sure that your USB device meets the above requirements, then try again.
If you connect more than one USB device, the system asks you to remove devices so that only the device you want to prepare is connected.
If there is not enough free space on the USB device, the system asks you to use a different USB device.
If you connect a USB device that contains files, the system warns you that the files on the USB device may be deleted.
The system starts to prepare the USB device.
When the USB device is ready, the message below is shown.
Remove the USB device and connect it to your computer. You can now download the new map to your USB device. [ show me how... ]
If TomTom HOME does not recognise the USB device, try the above steps again.
Try to get a new usb and format/prepare it for TomTom Home again with the maps. I myself do not have the nav model, so I would not know the correct steps but I think the maps can be prepared via the TomTom Home software or there could be an option on the nav?
Hello,
Thank you.
I am not sure, if you want to try go ahead, I think it won't work because the installer detects if it is a Fiat model. If the installer does not detect the hardware configuration, then it would probably not install anything. Just ensure that you don't have ROW or some other regional model out of Europe.
Sorry Jack, I was going to modify the whole Fiat OS to get the barebones Win CE Embedded system (or Windows Automotive, some sort of embedded os) and create an custom one.
Problems arose because each partition is firmware signature signed, so modifying the partitions will not flash as the system checks the integrity of the files.
Maybe you could try flashing the VP2 firmware if it is compatible it should go through, but I do not really think Fiat would have added support for the Peugeot models. If you could find an Peugeot firmware, we can replace the splash screen partition with the Fiat one, assuming, the signature used for the Peugeot firmware matches the Fiat digital signature.
Thanks for your help.
The problem is that I can't enter de navigation options or settings :( I can't confirm the version
When I press the "NAV" button, it's stays "loading" and don't inicialize.
I import the car from Germany to Portugal, dont know if it worked before.
Maybe I have to go to FIAT dealership to see what they say :mad:
Ah.
Before you go to the dealership (or if you are out of warranty), try the latest firmware version from here the '13.00.57.05 CO' version. It might be able to fix up the apps partition, but I do not know if the apps partition contains the relevant TomTom software, but it might :)
If it does fails to install with an red X upon checking the USB (like a couple of people in this thread), then this firmware does not support your model as it contains preloaded apps that require an specialised firmware (which I do not yet know how to get).
If you are in warranty, then go to the dealership, they'll probably also update the software as well.
Hi thanks for your reply. I updated to the Fiat Firmware but still the splash screen is Peugeot.
So how to replace this with the Fiat splash screen
Hi all, im new here, can you please tell or forward me the link to upgrade my 2013 fiat 500l trekking without nav! And what is the best fail safe way tp do it... please! Thanks!!!!
Hi, I have a 500L Trekking 1,4L from 06/2016 with Uconnect 5‘ includes Live NAV.
My Dealer Updates the Uconnect in Jan 2018 and the Most of all are fine now.
The only thing is, after this Update the eco:Drive don’t work, the Data’s don’t go in the Cloud and the App don’t geht new Data’s.
Fiat can’t Help, he saying it’s a software Problem and he don’t know any Fix.
Maybe a new Software Help.
Think you you get a new Update next Time?
Oh i forget my Hardware Information:
I've had a new unit fitted with the latest firmware. My Fiat main dealer hadn't got a working laptop with the Fiat software set on it. So they returned it to me without the Proxi alignment. This meant the steering wheel controls didn't work, the odometer flashed and, notably, the Fiat logo splash screen and usage warnings were not present.
For those who have the wrong splash screen, maybe, they just need a Proxi alignment.
Interestingly my Fiat main dealer told me first of all that it was not possible to update the software and refused to update it under warranty. When I pointed them to this newsgroup they said it was wrong.
At the same time my tyre pressure sensors started mis-reporting issues. The main dealer insisted that the 500L used the antilock brakes to indicate TPMS issues. On this forum I found the in-tyre TPMS sensor part number - which again they said was wrong.
So because they couldn't Proxi Align my head unit, I went to another garage to complete their job. While there I asked about the TPMS and they said immediately that it used in-tyre sensors and looked up the part number, which unsurprisingly, matched that on this forum.
The lesson - it's sometimes worth driving past your local Fiat dealer to find one that knows what they are talking about.
After my visit to my local dealer where they say that my gps problem probably was a radio problem and want to sell me a new 1.2k radio, I prefered to forget the GPS.
This week the radio had anothers problems, dont worked well, too slow and the screen turns black all the time. Dont had another solution that try to update to the firmware 13.00.57.05... and it's a new radio :) all the funtions work well and the GPS finnaly works :)
Many thanks to LordMetro by all this topic information
Cheers
Nice.
I can’t understand why give Fiat this Updates not free to the Users.
For me are the Fiat Managers Idiots
In January 2018 a have a lot of Trouble with my UConnect and after a lot of Pressure from me my Deale do an Update to 12.00.24.01.
The Problems are gone but at this moment my eco drive didn’t Work.
The Dealer say he can do nothing, Fiat say after months and maybe 30 Mails he can do nothing it’s a Software Problem and maybe it’s fixed in the Future.
Yesterday I do the Update to 13.00.57.05 and oh Wonder all thinks are Work and Eco Drive Work.
Fiat Dealers and Fiat are Stupid i......
I am back :D
Cheers
No problem.
I think the uConnect is not part of the MicroPod the dealers use, they have to manually visit the recall part of the wiTech site to download the radio update and do it. It does waste a lot of their labour time, so they probably do not want to do it :mad:
It's also no profit from them with their labour time, and many are inexperienced, so they just want to charge for a new radio :(
Nice.
I fully understand. I know other car manufacturers provide an online facility to update their infotainment systems but FCA is still behind in Europe (n)
In the US, FCA have a uConnect website where you upload your US VIN and it will provide you with the latest uConnect firmware package, years ahead from what we use :mad:
The US uConnect is different to our EU one, do not use their updates by the way or you will brick the radio
Yes, Fiat dealers are very bad. They honestly do not care about the radio updates and what's broken.
That is very bad of your dealer not performing the correct Proxi Alignment (n)
They do not want to update radios under warranty as this costs them labour-time which is probably unpaid when they could be working on other cars like servicing where they'll profit from a customer. Many dealers are just using the 'Fiat' brand and don't have a clue! (Mind you there are some good ones).
I have had dealerships rip me off, I asked for a service and they didn't change the oil at all, it was still dirty, the air filter was black - they just reset the service computer and called it a day :eek: Other dealers will try to use cheaper grade Castrol C2 as it is Fiat spec'd (or used to) and my motor runs a lot noisier on that. I just do servicing myself now as there's no reliable dealer, some good ones will stock Selenia (y)
They need a WiTech subscription to download the uConnect update on the WiTech recall page. This also costs them a yearly fee which is very expensive. Something over 1k a year when I last checked at Tech Authority.
As for TPMS, there are variants, one is indirect TPMS, which uses the ABS to calculate the air pressures, my 500L has this type.
Some other 500L cars use direct TPMS, which uses that sensor inside the valve to calculate the air pressure. It will go bad when the battery dies (probably 2 years), so you will either need to buy another one OEM or one with the correct radio frequency and then pair it with MultiECUScan on the car. So they're kinda wrong on that too.
Let's get this show on the road...
New update: 13.00.65.02
No online source for 500L, if you are working at a Fiat garage and wish to provide the zip file, just reply to this post.
500L Fiat Link (requires WiTech login): http://download.witexedi.aftersales.fiat.com/VP/VP2_CO_13.00.65.02.zip
The trick I used before with a German VPN to download the file no longer works. Fiat has patched this security bug lol.
It was uploaded in Dec last year so unlikely to have anything major anyway.
I asked the uploader of the 500X firmware but they did not want to provide it.
I am waiting for anything online about this firmware and so are our Italian friends at Alfa who also cannot get a hold of the VP2_CO firmware which is for the 500L and some Alfa's
FIAT 500X USERS - UCONNECT 5'
USB SWL Medium for VP2 - full update for all Fiat 520/521/334/226/MP/M1 variants except APAC (including preloaded apps)
FIAT PROJECT CODE 334: This is for the Fiat 500X
It should work, I'll try it in due time.
Source:
Fiat Link:
Mirror:
Changelog: Unknown, something to do with voice activation of the ecoDrive application, not something that people use a lot anyway.
A note to our foreign visitors.
The firmware provided for our UK/European uconnects CANNOT be used for the ROW (Rest Of World) uConnect units or you will disable the unit. (e.g. flashing on some Australian region when FCA do not service there)
Hi ! I'm from Brazil and I reachead here looking for an upgrade to my 5" uconnect nav radio (ROW). Actually I was looking for a way to change Fiat logos from the unit to Jeep logos because I bought this used radio from a Fiat Toro to use in my Jeep Renegade.
This is my radio and the SW version (see attached)
I've downloaded the lastest version you posted here ( #13 ), and even I've been warned, I decided to go ahead.
And Success!
(see attached)
I still have the blinking hodometer, as my jeep dealer was not able to do the proxy alignment. I've bought an multiecuscan compatible adapter to solve it, just waiting to receive it.
But my question is: when I prepare the pendrive to upgrade in tomtom home, It generates a file named ttgo.bif, which is a text file where you can read:
VehicleBrand=1
VehicleModel=35
Do you know which would be the values for the Jeep Renegade? Maybe if I change it, the radio would display Jeep logo and graphism ?
And Success!
(see attached)
VehicleBrand=1
VehicleModel=35
Hi there,
Great news about flashing the EU model on ROW. I have heard many stories on the Alfa Romeo forums about it bricking - so it appears to cause issues on some variants of the radio. :D
For the splash screen, I've been asked before, and from what I can diagnose, I think the radio's cfe bootloader has the splash screen configured from factory and cannot be changed. Think of it as your PC BIOS splash screen, the firmware inside the bootloader is controlling this.
Because the splash screen images come from the UUID of the device, in this case, the '226' parameter, this causes the installer to install the features of a 226 vehicle. As far as I am aware, without direct nand modding, there is not much we can do.
I tried to decompile the firmware images before, but they're digitally signed, so there is no way we can mod the actual Windows CE system on it through USB firmware packages - I had many ideas to improve the firmware but as it is locked, we can't do much. I guess Fiat doesn't want us snooping around stealing proprietary uConnect software (maybe why the blocked the official download links)
As you have a nav model instead, maybe the tomtom parameters can help? I assume they're for the TomTom app features in something, I do not think it would work with modifying the actual System bootloader as that is not booting off the USB but try it out with different values - you never know :)
I would try a proxi alignment when your tool comes, be careful with elm327 tools, some don't work as they're missing the Canbus protocols and only do generic testing. You'll need to find one preferably on Aliexpress with a PIC18F25K80 chip (and FT232RL interface if USB), look at the board design and see if the resistor 121/120 is present - if so remove that with a knife and it will work fine. I've tried this on many elm327 v1.4 Usb PIC and elm327 vgate bluetooth PIC (alfaObd on Android/PC can do more settings on proxi alignment - but I found MultiEcuScan to be more stable). There are many fakes without this chip so I compare the board design images with the ones on the MultiECUScan forum to determine which work.
