Technical  Turbo Boost Leak
ZippySnappy
South Africa
My Panda has had it that in the past, the Engine light would come on, triggering the P0236 & P0244 error codes, both of which are turbo leak-related. Up until recently, I was only able to find the actual Turbo leak on one of the housings. If anyone else has experience with such, please share to help others. Here is a video of how I managed to find the leak:
Model
0.9L Twinair 4x4 Lounge
Year
2017
Mileage
42185
I have used blanking adaptors and a air line set to around 20psi to locate turbo leaks, often found on damaged intercoolers or hoses.
The smoke machine where available, is good as it quickly shows the cause of leak, when they first came out it was too expensive for many DY mechanics however I see they are a lot cheaper now.:)
Yep, a smoke machine is a handy thing. I had a boost leak on the intercooler to inlet pipe. It's got quite a severe bend on the that pipe and I guess it just eventually split. Not expensive or difficult to replace if it happens fortunately.
