Idea  Tricky starting...
timart4
Hello, I have a Idea 1.3 Multijet 2004 It’s been very tricky starting it on these now cold mornings in the UK. When it finally start it kicks out a lot of white smoke. I have changed the glow plugs which has not made any difference what might you suggest next.
Check all 4 glow leads are getting power ;)
Fundamentals:
You need hot plugs : 12v supply
Injected fuel : crank speed
You have smoke.. so its telling me fuel is being injected..but unburnt until all 4 cylinders are warm :eek:
2 things to try..
Warm plugs twice before cranking.. can help with initial heat
Depress clutch when cranking.. less load on starter.. so a faster spin.. better compression effect
Also.. IF the H.P. Pump is tired extra rpm will build additional rail pressure
(I dont think thats your original issue)
