i htink oulton park (sp?) would be a good first time track iirc its not a complex track (from toca TC anyways )
charlieboy said:i htink oulton park (sp?) would be a good first time track iirc its not a complex track (from toca TC anyways )
It's not technically too complex, but it's very undulating, which can cause lots of suspension strain. I know that the Superbikes often suffer with overheating suspension at Oulton Park, simply because the amount of compression and extension of the dampers is much higher than at any of the tracks they test at.charlieboy said:i htink oulton park (sp?) would be a good first time track iirc its not a complex track (from toca TC anyways )
ill be coming to see you go round tracks i guess. but if you stuff it ill cry!!Dunc Uno Turbo said:will deffo be doin track days with my UT when its fully built and resprayed. but im a nutter and will be goin on the lines of who gives a crap about stone chips and stuffing it! im building it for track days and pod really, so will be goin as hard as i can in it
Dunc
That's the spirit! However, I'd suggest looking at a roll cage, to reduce your chances of dying.Dunc Uno Turbo said:will be goin as hard as i can in it
hes haivng a full custom one madehmallett said:That's the spirit! However, I'd suggest looking at a roll cage, to reduce your chances of dying.
H
H
parden hehealainax said:didnt do the strip just showed on stand
xxx
same herebulldog5046 said:i'm in
