Technical  Towing automatic panda
kezzy
I have a automatic panda that starts but i need to tow. Should i start it, leave it in N /neutral to tow it away ?
The wheels will be rolling on the ground.
Is the issue with towing an auto just to lubricate the gear system ?
You should be using a solid tow bar between bumper eyebolts on the tug car and towed car. This solves most of the braking issues. With engine off, steering is a bit heavy but you don't want too much as the trailer car will follow the tug. The towed driver just needs to add input for tight turns and avoid over-steering at faster road speeds.
On fast roads, 55mph is ok any more causes the towed car to weave.
