TF1170-3 30amp
Page 38..
TF2218P
page 25..
on this:
http://www.rydertowing.co.uk/pdf_checklists/Practical Guide.pdf
Its in PDF if your pc wont load it you need the program to view it its a Free download from ADOBE
http://www.adobe.com/products/acrobat/readstep2.html?ogn=EN_US-gntray_dl_get_reader
as for your other questions:
The leaflet which came with the split charge relay says I should run a twin core 44-strand cable to it from the battery and to use both the feed terminals on the split charge relay to spread the load. So I presume there is no direct connection to the battery's negative post and that I am to connect the negative to a bolt on the body? If there is a battery connection, do I run a 4 core cable?
No connection to the Negative post. there should be a decent earth under the trim in the boot where the rear lights are earthed..
you will only need one earth for the split charge relay as there is only one terminal.
Do I just feed the 7-way bypass off one of these terminals on the split charge relay?
Do I put a separate fuse on each cable feed near the battery or is there a fuse box in the engine compartment to which the battery feed can (or does already) go to a fuse to which both postive feeds can be connected?
Put it on its own supply as i mentioned earlyer it will continue to allow the road lights to work in the event of a short circuit blowing the smart charge relay.
Separate fuses you will need 2 one for the By-pass relay and one for the Split charge relay
http://www.emergencyequipmentshop.c....html?osCsid=f2a030005529aed9f0ab581bd7ac22cc
(standard will take 30A)
alternatively this will look neater
(in 2 way)
what i'd do the way the charge relay takes 2 feeds is run a 30amp cable from the battery to the fuse box (Id personally go for the box with a lid as its better built than the inline type)then use a blue lucar piggyback connector with a bit of heat shrink to insulate the spade part which would push onto the fuse with cover connection
http://www.maplin.co.uk/Search.aspx?criteria=L27AY&DOY=23m12
and fuse the by-pass relay in second fuse holder
Do I fit both the split charge relay and the 7-way bypass relay in the rear of the Multipla?
Which side of the Multipla do I run the cables? I have seen pics showing the connections to the 7-way bypass relay being made to the rear O/S lights, but feeding the cable to the 12N through a grommet on the N/S floor! I haven't lifted the carpet yet so don't know how simple it is to run cables from the battery.
This is the bit where you need a Multipla owner
but both relays go somewhere behind the boot liner where you can get the leads out to the sockets outside the car as for getting cables across the car run them down which ever sides easy then run it across the boot behind the boot liner near where the boot catch is..
