Technical  Torque Sensor.
Hull
Had this fault for a while and I believe it's the torque sensor.
I lose power steering. Engine off and on fixed it, but a left turn makes it come back on.
I can see clock springs for sale, but either as one unit. Or as a complete set with wipers and indicator stalls attached.
Does anyone know which one I should be buying?
Thanks.
Clock spring has nothing to do with power steering
There is a torque sensor
You can read this with software
Graph it raise the revs to about 2.5K
Turn the steering left and right a few degrees
Until it starts to fail, see if it fails at the same degrees
If you do this does with raised revs does it go from lock to lock without failing
The one to buy is the one with the same colour connector as you original
Reseat the connection first, it fixes a fair percentage of faults
Certainly looks like the torque sensor in the video
you need to find out what colour to order
Here the instructions
I always found, it they are fine in one direction but not the other, feels funny or stops working it the torque senses, yet to have one fail on the Panda but have in other delphi systems, they seem fairly reliable as long as they don't get damp, but can wear out
Here the instructions on how to fit one
The car has done 153k so I assume it finally given up.
It's going to a garage for an mot. I'm gonna let them install it.
I have had two do 200k just under and over
Fairly rare so probably just bad luck
I believe @irc took one to pieces and it was corroded but I might be remembering wrongly
Sound like it might have been a side effect of block scuttle drains, some time in the cars life
Good memory there @koalar
Yep, probably the scuttle drain on that one.
Since then I have had another one with similar symptoms to the OP. This was on a high-mileage 1.1 Active with soon-to-be terminal sill rot so I didn't bother repairing it. I persuaded the owner that it had reached money-pit status and pointed them at a nice 10-plate Active Eco to replace it. The column is still in my "when I get round to it" pile, so it may get done if I use up the other 4 spare columns I have on the shelf (so probably not).
Although, last time I checked, torque sensors were £60+ so if they are cheaper now i may get one and fix it, just because its there.
Whipped the cover off today to see which colour I needed to order. (Blue)
It is a bit rusty back here.
Photo 1
Blue sheathing
Follow the blue wire back
It should end in a squarish connector like this
Before you order a sensor unplug it and plug it back in
It fixes a percentage, if its oxidation on the pins
Only if that fails order a new sensor
It will not fix the dash light though
Dim LED warning lights are nearly always damp got between the PCB layers
There's no easy fix
Send it away, dearest option
Replace second hand, has to be lower milage
Live with it
