A self made stuff for rear brake springs: sufficiently long (lower quality) flat screwdriver with a notch sawed through the tip. You can push a spring into place with it much easier than pull it with pliers.
Otherwise for replacing rear shoes and drums: 19 socket to remove the wheel, 12mm spanner to remove the securing pins, pliers, piece of soft wire (or equivalent) to secure the cylinders, and two screwdrivers to leverage in the new shoes after they are mounted, so that the drum slides in nicely. A hammer may get handy too.
/Woj
