tips on how to improve gearbox..please look in..
M
Mike
hi i have a 1.2 bravo on 51 plate
was told gearbox are risky on these ive done 50k
what can i do to get the best out of the gearbox..
ok drive carefully not erractic..but seriously under the engine what can i do
was told the oil can be looked into
there is a baulk something as well
please advise
i need to look ater it as i dont wish to pay out for a new gearbox so soon
please note im sure the gearbox is soon to go,,someone mentioned the synchro mesh
what is this and how can i do little things to improve it rather than jump to a gearbox..
synchromesh' dont usually go on the 1.2, its normally the diffs
as for prolonging the life of it, drive sensibly, dont accelerate fast from standing starts and dont slam through the gears etc, just be gentle on it and it will be fine
you can change the oil and that should improve gear selection and you will also be able to see if there is any swarf in the box aswell. before you do the change take the car for a short drive to get the oil warmer
Andy_sx
you can buy additives to put in gearbox oil, im usually aprehensive with such additives but it worked well for me.
Stu
hmm i can use this info what was that baulk thign mentioned?
Baulk thing...??? got a link or anything, dont have a clue what you are on about
how do you change the oil in the gear box or add aditives
ok well i wouldnt bother with bauk...
its alot of hassle really, easier getting a new box tbh
as for the gearbox oil, you need a 12mm sump plug key, take the car for a 10 min or so drive to warm the oil up then jack it up a bit, say 1 notch on te axle stands at the bck of the box, at the bottom of it there is a hex bolt, thast your outlet, drain the oil out then refit plug
then on the front of the box opposite the rad is the fill plug
the 1,2 takes 1.8 litres of box oil, but just keep filling until it starts to spill over and your done :)
Andy_sx
I read somewhere that it's a good idea to avoid using the gear selector as an arm wrest or hand support while in drive but thats probably got more to do with damage to the linkages.?
L
1
832
Dark Lurker
P
15
12K
Dark Lurker
3
7K
Steve
S
F
7K
F1-ANG
F
