Technical timing belt
padone
hi have been quoted £160 to change my timing belt and water pump on my 1.9 jtd punto if i pay cash by my local fiat specialised, have owned the car for about 2 years now and done about 20,000 miles and from the paper work i got with the car i can't see when it was last done, is there anyway to check the condition of the belt? and do you guys think that it is a reasonable price? thanks
There is no real way to check a belt while its on the car as the backside of the belt is only a patial indication of age and wear
It needs to be off to fully examine in - in which place, you might just as well get a new one on
As for water pump - ensure they use fresh coolant as well :)
Ziggy
thanks, was going to change the coolant today actually but waiting till the end of the month till i get paid for a timing belt change, do you think i should just wait for changing the coolant then? and if it a okay price? do most of the thing myself thanks to the website, but really don't want to try anything like this just incase i **** everything up :\
The belt on a 1.9 is a bitch to change because there is little space under a punto bonnet with a water pump as well I would have though £160 is pretty reasonable the water pump and belt kit is likely to cost £75-100 and there is a couple of hrs labour involved
Hello.
Re: (is there anyway to check the condition of the belt?)
A: No.
a timing belt might look brandnew or in goodshape but it means nothing
Timing belts have improved over the years in quality but ive found tensioners can let go first making it look like its the belt thats failed.
so changing it for peace of mind if no history is best bet,
