The crank pulley bolt is not an item you use on the engine, it's something that's already there.
Search around on google for an identical copy of the fiat punto you have of a crank pulley. Once you've found an identical of yours, you can go to your car and there should be the same thing with a bolt in the middle of it. BEFORE SPINNING IT, LINE IT UP WITH A MARKER AGAINST THE BACKPLATE, this is so you know where it was originally. You spin that bolt and it turns. This is what you turn to line up.
As you may have the 8v, you can't kill your engine if you improperly position it. Follow the thread on my profile and the people there explain it quite well.
If you didn't mark the position prior, the crank pulley for me was (in terms of a clock) was at 1PM in order for the engine to turn over once you've put everything back together, may differ on yours but i don't know
