xeuyi
Hello, I have a 2013 1.2 petrol panda. I recently changed the alternator belt and the timing belt, making marks to ensure the cogs were in the same place as before I took the old belt off.
I started the engine and it sounded better and smoother than it was before. No issues.
However, I took it for a drive and I got misfires cylinder 1 and cylinder 4. Pull over and restart engine: idling fine with no apparent issues. Again misfire cylinder 1 and 4 when driving after 10 minutes or so. But always fine when restarting.
I read online this may be due to the timing being 1 tooth off so today I opened it all up to check. After checking I am 100% confident the timing is the same as it was with the old belt and it is lining up with the markings I made.
Has anyone had a similar issue or any ideas as to what it may be? The spark plugs, coil pack and injectors are a few months old. I haven't moved anything to see if the misfires move with it. It seems too much of a coincidence it happened just after the belt change.
Thanks in advance
Thanks in advance
