Technical  Throttle body - 100HP
BreakerBarDanny
I'm having a no start issue with my car after it has sat for several months, the car would crank with no signs of life, after changing the fuel pump, the engine would kick up to 300-400rpm without start.
After checking the fuel injectors, they seem fine, but what I've noticed with the throttle body is that the butterfly valve seems stuck shut, and my main concern is that maybe the engine isn't getting enough air because I can't find any sort of idle control valve.
Any help would be much appreciated.
I think danny is right about the relearn.
I did it unintentionally in mine, by just having the ignition on for a few minutes, and not touching the throttle. Mine had too much play in the pedal, and reacted a bit weird to input sometimes. I don't know if this will sync the throttle body as well, but it's worth a try at least.
