fiatERR
2012 500L
I have a problem shifting gears. Car turns on and there are no DTC fault codes. The F16 and F84 fuses are fine. I have not checked the starter or sequential gearbox relays as suggested by some YouTuber mechanic. I pulled the battery and tray out to check the shifter cable and bushing. Both are intact, and the cable rotates when I override the shifter and shift to R and N whilst the battery is removed. AFAIK, it is functional.
Here's basically what I do in the video:
1. Turn key to 1st position
2. Turn on ignition
3. Shift to R (nothing happens)
4. Shift to N then D
5. Try to shift back into P, but there is a grinding noise
6. Contemplate driving off a cliff but realizing I am not able
Maybe one of you can figure it out.
2. Turn on ignition
