Howdy,
I have a 2012 pop with auto transmission issues that have been steadily being getting worse.
It started with failing to "engage" sometimes, so I would put it into to Drive and it would just rev (with a bit of a grinding noise). The only way to get it to drive again would be to turn the car off and on again (shifting to P, N or R, or manually selecting a gear didn't reset it).
Just recently it totally failed to engage, and I had to push it home (luckily happened close to home!). It can be pushed no matter where the automatic shifter is, and the display accurately reports the position of the shifter, but the car is in "Neutral" as in I can still push it. There is also a terrible grinding noise if I rev it.
What could this be? Seems like I might need a whole new transmission?
Thanks for any ideas.
