The one and only code for fiat radio thread.
Hey thanks for the code but that’s not working? It’s still showing as radio blocked / wait?
Am I doing something wrong?? Thanks
Just checked it again, and 2362 is the correct code for the serial number you posted.
If the display is showing Blocked / Wait, it's because someone has tried the wrong code too many times. You need to leave the radio and ignition switched on continuously until the message clears. Depending on how many wrong codes have been tried, the waiting time could be up to 24 hours.
Hi thank you for the update. I’ve waited the recommended time and the blocked message disappeared. Then radio was showing “enter code”. I’ve entered the code you’ve provided but still not working. It’s now gone to blocked again?
If you've only entered the code once, then according to the table above, you should only have to wait 1 minute before the blocked message clears.
Do you know the method of entering the code for your radio?
For some radios, to enter code 2362 you need to press button 2, then button 3, then button 6, then button 2.
For some radios you need to press button 1 two times, then button 2 three times, then button 3 six times, then button 4 two times.
You may also need to press "ENTER" or another button for the radio to accept the code.
There may also be a short time limit for entering all 4 digits of the code.
You will need to consult the radio's handbook to find out which method is correct.
Hello,
For me it also does not seem to work.
SN: M127867
Fiat Part no: 735392561
Visteon part no:VP4FCF-18C838-BA
That gave me code: 9096
But that does not work. I have tried it several times, but everytime the timer doubels in length...
Please help
EDIT: It worked.
I’ve been directed to this thread as I gave a Blaupunkt Fiat 500 head unit that I need the code for if you would be so kind.
815 BP829090808066
312 SB05 S&S
7 648 290 316
034502
These are all the numbers on the side.
Thank you in advance.
I have the code for your radio.
Click the link below while logged on to the forum from a computer, not a phone.
https://www.fiatforum.com/donations.php
Use the PayPal button on the left under "Make a donation.".... Do not use the button on the right under "Make an anonymous donation"
815 BP829090808066
312 SB05 S&S
7 648 290 316
034502
Thanks for donating to the forum. (y)
Your code is: 5331
