Hi, I need a radio code for my Fiat Punto. I have attached an image with serial number etc..
Also my radio is stuck on RADIO LOCKED/WAIT I know the wait time can be long but my radio turns itself off after 20 minutes so will I not be able to put a code in as the timer resets if the radio turns off doesn't it?
7 468 542 316
85CM854291852702
I have the code for your radio.
Click the link below while logged on to the forum.
https://www.fiatforum.com/donations.php
Do not use the anonymous option to donate.
You will need to leave the ignition switched on continuously for the duration of the waiting time.
If you've tried a lot of incorrect codes, then it would be better to remove the radio and connect it to a bench power supply.
