The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Hi, I need a radio code for my Fiat Punto. I have attached an image with serial number etc..
Also my radio is stuck on RADIO LOCKED/WAIT I know the wait time can be long but my radio turns itself off after 20 minutes so will I not be able to put a code in as the timer resets if the radio turns off doesn't it?
7 468 542 316
85CM854291852702
I have the code for your radio.
Click the link below while logged on to the forum.
https://www.fiatforum.com/donations.php
Do not use the anonymous option to donate.
You will need to leave the ignition switched on continuously for the duration of the waiting time.
If you've tried a lot of incorrect codes, then it would be better to remove the radio and connect it to a bench power supply.
Hello,
please, i need help with my Fiat Croma. Could you help me with CODE to Radio?
SN: 815BP534253728206
Fiat 194 CD
BP-Nr:7 645 342 316
Fiat-Nr: 735 418 045 0
Thank you very much
Asar
Hello,
Fiat 194 CD
BP-Nr:7 645 342 316
Thank you very much
Asar
Please!!! I need the device code CD5404MP3 FIAT.
The information I have:
A2C53290039
HC0012200057408
FIAT 41789 100179535
100179535 B830-SECURITY
Hi darven,
I can imagine that is difficult for you to read al the images with codes. So here is a new post with all information:
Fiat 500 2008
Fiat 312 MP3 SB05
BP Nr.: 7 646 383 316
815 BP 638389510238
If any other information is required, let me know!
Hi darven,
Fiat 500 2008
Fiat 312 MP3 SB05
815 BP 638389510238
Davren
I have received second hand headunit this morning from typecastboy. I'm hoping to change the fascia with my faulty radio!
Not 100% it works but we don't have the code, could you help at all please?
FIAT 312 SB05 S&S Ivory
7 648 290 316
BP829091610790
