The one and only code for fiat radio thread.
Hi all
I have a 2006 scudo JTD and I don't have the code, The internal light was left on and it drained my battery. Only the radio works on it the CD player doesn't seem to want to play.
Would you be able to give me some advice as to where I can go to get the code?
Hi all
For Clarion PU-2294A(C) radios, I need the barcode number similar to C7000000xxxx
Post the number (not a photo of it), then I will let you know if I can get the code for you.
pls help me i have a fiat grande punto t-jet 2009 and i have a radio code problem
my BP854399831951
7 648 543 3316
pls help me i cant find anything :(
hi everyone iam new in this forrum pls i need your help
I have an fiat grande punto t-jet 2009
And my radio just blocked and i need a four number code
But i found this serial codes
815BP854399831951
7 648 543 316
i have a fiat 199 mp3 SB05:cry::cry::cry::cry:
815BP854399831951
7 648 543 316
Hi, and welcome to FF,:)
I'm sure Davren will see this in the next 24 hours , and let you know if he has access to the necessary code information,
Charlie
my BP854399831951
7 648 543 3316
I have the code for your radio.
Click the link below while logged on to the forum.
https://www.fiatforum.com/donations.php
Do not use the anonymous option to donate.
Hi there I'm new to this and I am try to get some help with the code for my radio in my Ducato 2005 if anyone can help please
The numbers required by looking at other enquiries are
Bp-nr. 7 643 318 316
Fiat- nr 735 388 377
BP331857206331
Many thanks
BP331857206331
Many thanks
need a Fiat 500 radio code too...
Hello Davren,
I need a Fiat 500 radio code too... I bought a second hand 2013 car that has a new radio fitted into, and still has the old Bosch one in a box (without the code). The new fitted radio is an awful modern one with a retractable screen that does not fit the little car at all, so I would like to re-install its original radio. The serial number is as follows:
Bosch
FGA PN: 735 585 258 0
S/N: 16289
I hope it is possible to get the code. thanks!
