The one and only code for fiat radio thread.
Hi Davren,
Thanks for the number but when I enter it, which I've tried twice, I'm asked to wait & then it comes back up asking for the M-Code.
Any ideas anybody please? I don't always listen to the radio but when it's not there I miss it :-(
Re-reading that last bit, I thought, bit like the wife really! :)
Gav
Hi Davren,
Gav
The code is linked to your serial number, if it doesn't work either you've given the wrong S/N, or someone has manually changed the code in the past. I'm not sure if Visteon units can be decoded if the latter is the case.
Hello, I need the code for my 2012 Fiat 500 CD player
The numbers i got is:
"P/N 28317093"
"(P) 1RZ26JXWAG"
"TxxYD182110359"
"7093M111820359"
Thank you.
Hi
So I was just wondering is it possible to get the code for the stereo in my Grande.
The serial number looks to be FA588871261639
Not sure if this is right or not as there are that many numbers on it.
Danny
Hi
Danny
Sorry..... I don't have a calculator for Grundig radios. Most have to be decoded at a radio workshop.
an anyone give me the code for my car radio, little'ns messing with interior light in back resulted in flat battery.
BP-Nr. 7643331316
Fiat-Nr. 735391102
BP333142225205
BP-Nr. 7643331316
Fiat-Nr. 735391102
BP333142225205
I have the code for your radio. Click the link below while logged on to the forum.
https://www.fiatforum.com/donations.php
Do not use the anonymous option to donate.
must donate to receive code, if it's only flat battery the radio should work as they are coded to the car (y)
Re: The one and only code for fiat radio
Hello, great forum, just joined after searching for radio code for my system, numbers are bp nr 7643389316 and fiat nr 735403207. I will make a prior donation to the forum if you would be so kind to provide a link. Thanks, Dave. (y)
Thanks for donating to the forum. (y)
You've posted the Blaupunkt and Fiat part numbers for the radio, I need the serial number. For your radio it will be something like BPx389xxxxxxxx and should be stamped into the side of the radio.
